When I click on "Show blank screen" under "Actions" it automatically checks the "Disable remote input" . I am running an auto it app on the host and need to just blank the screen.
How do I do this?
Hello @mikeddailey32
Thank you for your post, and welcome to the TeamViewer community!
In order to blank the screen on a remote device, remote input must also be disabled, so that a local user at the machine you are connecting to cannot interfere (as they are unable to view the screen).
You can find more information here:
Hope this helps clarify 🍀
