Intermittently doesn’t login, must restart several times for a successful login and showing an ID number with password.
Can’t access remotely and check TeamViewer and shows no ID or password and the sign in at top left shows trying to login, but does not. Check settings and quite a few had changed for remote access which I corrected. However, under security get a yellow triangle with “!”. About “easy access and personal password has been configured”, with the option to change or remove the password. I clicked on this and it goes to advanced settings in preferences. Use only for personal use with no security risk, and wondering what I should do? I have to restart a number of times and finally I get the usual username and account type with my ID number and password which changes each time.
Haven’t had a problem in a couple years, but had a big one back then which took a couple weeks to fix. Hoping someone here can help me or assist in what I should do to make TeamViewer happy with Big Sur 11.6 and TeamViewer 15.2 2.3?
Should I change the password, as it’s been the same one without a problem for nearly a decade? It is an eight character password, perhaps not there most complex, but get Moderate at most places.
Best, Seth Thomas MD
