Hi! I've tried Host and Quicksupport, both seems require Universal Add-On, but when I try to install it it tells the TV is not supported. I've tried to force it wonloading apk and installing it, but seems I have no effects, no errors too.
Now by both teamviewers version I can see TV remotely but I can't control it remotely. Should I root the TV to have Universal Add-On working?
There is any other way to control TV? **Third Party Product** is not installing, it tells there is needed to have the main program, but on google play there are only 2 icons and I've installed both. Any other program/way? Thank you a lot!
