I have a Raspberry Pi3 running all the latest versions of software. I can remote in with no problem when a screen is connected to the Pi3. When the HDMI is disconnected team viewer does not connect and displays initiating session.
I have read many previous posts on this, it isn't the same issue as the Pi4 where you need to set the resolution. I can connect with VNC and it works fine with no HDMI connected, its just team viewer which doesn't work.
Anyone got any ideas on this?
