Need help with setting up Wake-on-LAN
I have been trying to setup the Wake-on-LAN feature but without success.
Here is what I have tried so far:
1- Enabled wake on LAN options on my motherboard BIOS.
2- Enabled wake on LAN options in windows LAN settings (Wake on magic packets, Allow to wake, disable fast startup).
3- Setup port forwarding in my router to port #8.
4- Setup TeamViewer Wake-on-LAN options to public IP address and port #8 (I have a static public IP address).
Here is the specifications of my setup:
1- Motherboard: MSI PRO Z690-A DDR4.
2- OS: Windows 11.
3- Router: HG630 V2.
I am trying to wake my computer over the internet via the teamviewer android app but it is not working.
  • Valeria2
    Valeria2 Posts: 605 Moderator
    Hello @M_Sedahmed
    Thank you for your message and it' s great to have you in our Community.🙌
    I see that you have followed some of the steps for the installation of our Wake-on-Lan, however I would recommend that you visit the following link:
    👉️Activate Wake-on-LAN (WOL)
    I would also suggest that you take a look at the Manual that will lead you to a deeper understanding of the topic.
    In case of doubt remember that we are here to assist you.
    Moderadora de la Comunidad en Español/ Spanish Community Moderator
