I'm new to TeamViewer. I had it on my phone but there was an icon that show up on the side of the screen that I could not find a setting for. I have uninstalled the app but the icon is still there. Can anyone assist with guiding me with removal?
Thanks mtjay. The home minister figured it out for me. I may try to reinstall and see if I can get it to work the way I wanted without the quick support addon.
I had the same issue, if you remove the quick support addon which is a separate app that installs at the same time the icon will go.
See what's new at TeamViewer
