JIRA Integration guide does not match reality
TVNZ
TVNZ Posts: 1
edited May 2024 in Deployment & Integrations
Hi all. I am hoping for some help with JIRA cloud integration to Team Viewer. I have been reading the integration guide, but the guide does not match what I am seeing in the JIRA and Team Viewer portals. https://www.teamviewer.com/en/global/support/knowledge-base/teamviewer-classic/integrations/3rd-party-integrations/jira-integration-configuration-guide/
I have created the app in JIRA, and left the customer link template at the default - because there is no information about what this does, or what values you should put in it.
The next step is to "Copy the provided redirect URI provided in the plugin". However it is not clear where you get the URI from. The JIRA app does not have a URI associated with it as far as I can see. Where do I get the URI from?
Thanks in advance for any help with this.
  • GTRRRRR
    GTRRRRR Posts: 1
    edited October 2024
    I am also struggling, but I can help with the URI. I believe that's the permanent link provided for our custom module in your Admin Settings → Custom Moduls (f.e. https://custom.teamviewer.com/…. )
    My problem is, that the guide says:
    "9. Copy the generated client ID and client Secret and paste in the Jira plugin."
    but the Teamviewer Jira Cloud plugin has no configuration field to entering this. Does anyone know, where I can enter the client id an secret in Jira Cloud?
