I hit connect. It say it is awaking authentication and nothing ever happens. Why?
Hello @samowens,
Thank you for letting us know that a fresh installation helped to solve the issue! I am glad that TeamViewer is up and working smoothly again for you!
Feel free to visit the Community again to share your TeamViewer Journey 😊
Wish you a nice day!
Oh I had to check the unassisted access for it to show up so I can add the device to My Computers. Thanks for your help.
I ended up just doing a complete uninstall and download. I went thru the setup and it works now. That seems to be the fastest way to get rid of old legacy settings like personal password.
Thanks for the replies and the screenshot! @samowens
Is it the screenshot from the TeamViewer client on the remote device?
Is it possible for the supporter side to input the remote's password to complete the authentication? The random password can be found on the Remote Support tab below the TeamViewer ID from the remote TeamViewer.
(TeamViewer at the remote side)
In any case, the random password has no show and is disabled. Let's try a different connection method. Check the TeamViewer on the supporter's side to start an Easy Access connection. You may check out the option under connection methods.
(TeamViewer at the supporter's side)
Let me know if the information above is clear to you, and I hope to hear the update about the connection too!
whats the difference between groups and device groups, one pc Boris is missing from device groups
all pcs are windows 11 and i migrated them
i am doing this on the same lan with 2 pcs next to each other
i does not even work if i give it the ID and password from the remote, does the same thing, eventually times out.
Hi @samowens,
Welcome to the Community, and thanks for sharing your scenario with us!
Sorry to hear that you experienced a connection hiccup at the authentication stage. Please check the TeamViewer version and ensure it is the latest version for remote connection.
At the same time, to better understand the connection set up, can you share the screenshot of the connection, and the TeamViewer client type you have chosen for the connection on both sides please?
