Good morning. For a few days now, following the latest updates, I've been unable to hear audio—or rather, sounds produced by remote PCs, which has always worked. Can you help me? Thanks.
Gent. Chisa,
grazie per la tua risposta che è corretta e funzionale, problema risolto.
Perdona i tempi di risposta.
In futuro mi rivolgerò nuovamente alla comunità.
Cordialmente, Alberto
Hi @studiomorello ,
Thank you for your post in the TeamViewer Community!
Could you please try the following steps: On your local device, sign in to your TeamViewer account, then navigate to:Settings > Remote Control > Session Settings > Outgoing Connections From there, activate "Play device sounds and music."
Could you try starting a remote control session to check whether you can hear sound from the remote device?
Let me know how it goes! 😀
Chisa
Hi @studiomorello,
Thank you for the update! We're glad to hear that the issue has been resolved. 😉
Wishing you a great day ahead. Best, Chisa
