Hello we have installed team viewer onto 10 machines, all practically identical.
All work bar 2. These machines connect and you can see te screen as it should be but when you open an application the screen turns white, or text boxes are missing, now I know they are there because whn I click on the screen the function happens but I can't see it.
The only difference I can find to the other machines is that on these 2. They both have 2 monitors (as do the others) but in this case when checking the systems of the ones not functioning properly they only register 1 monitor. The ones that work show 2 monitors?
Can anyone help?
Tony
