Hello!
I'm trying to install TeamViewer, but cannot open the disk image containing the installer (double-click doesn't open it :smileysad: ), someone can help me, please? Thank you
hi guys,i have solved this problem. i connect my tv to macbook, and the install window will show on tv screen even my tv is power off. OMG!! if you have more than one screen connected with your mac,please check it maybe you will find the install window. : )
I HAVE A PROBLEM
I Could not install teamviewer on my mac after download
after the double-clic there is a file on the desk with no possibility of installation
Can you tell me please how you run command ?
iainwels . don't you understand that is for Mac? The exe file is for windows my friend.
oh so maybe this is my problem too.
Hello everybody!
Problem solved! :womanvery-happy: It was an hidden window, made visible with the command "Show all floating windows" :womanembarrassed::womanembarrassed::womanembarrassed: ... Sorry for the touble and thank you for all!
I've tried downloading another app and had no problem openig the related .dmg....
Hello Francesca71,
I am just an teamviewer user, but i think you need to call apple support for this. That a launch program won't open is a problem with apple i think. I am sorry. I will make sure a moderator see's this as wel! @Jonathan could you help with this one?
No others files named TeamViewer... :womansad::smileysad::robotsad::mansad::catsad:
Maybe a dumb question but did you look for any file's that is named teamviewer? If not maybe the program did not delete them all. If you could check that would be nice!
I hope this helps.
No, there isn't. Few months ago, I downloaded and installed the application successfully but some days ago I have to unistall it. I do not know there was an unistaller, so I did it as always on Mac: throwing the application to the trash using AppCleaner (an application that allows you to uninstall apps and remove all the related files). But if this method was the reason why I can't install Team Viewer again, I had to have troubles during the installation, but my problem is that I cannot open the folder that contains the installator.
Is there some kind of pop-up that says the error?
I have already checked it a and tried to download again... :womanfrustrated:
If i am a bit off, i am sorry i am not a mac user, but did you try to open it as an administrator? Did you try redownloading it? Is your memory full (this could couse the teamviewer client to not completely download)? If you could check these things and then awnser with what you have seen, maybe we could work something out!
Good morning and excuse me, I couldn't replay sooner.
I downloaded the application from the page you can see in the link and have .dmg file. I have drag it in the application folder and double-clicked it to have the disk image that contains the installator
https://www.teamviewer.com/it/download/mac/?pid=google.tv_exact_sl2.s.it&gclid=CjwKCAjwpfzOBRA5EiwAU0ccN-D_mmmdADcStGKwaCam0RHuSgUe8Ca_jX3_IZ829RNrJdkuKUz9OBoCUrUQAvD_BwE
https://www.teamviewer.com/it/download/mac/?pid=google.tv_exact_sl2.s.it&gclid=CjwKCAjwpfzOBRA5EiwAU0ccN1Vnh7F3PGdYyWkpurYgvKnEaAQ4m14Rpfyjji_RtWBLIpazSIrORRoCADAQAvD_BwE
@iainwels wrote: Hello Francesca71,Which one did you download? Is it the .exe file? Could you send me a screenshot?Thank you for using teamviewer
