1) Slow start problem: I create custom QuickSupport module v12, v13 but when i run my executable it take too long time to start ~2min. I make test and run on same PC original version of QuickSupport v12, v13 - it start imediately. Previous version of custom QuickSupport created for v10 start quick. Customer doesn't know whats going on, if it's running or not. There is no startup progress dialog or something like that. From QuickSupport start happening SlowSupport :-)
Edit: analysing deeper i found that TeamviewerQS.exe creates in temp another exe, run it with configuration parametrer: "..Temp\TeamViewer\TeamViewer.exe" --configuration XXXXXXX, then it do something 2 minutes and after that creates tv_x64.exe + tv_w32.exe that is final TeamViewer application. It looks that maybe all configurations are now stored in cloud and downloading from web and it's not stored inside TeamviewerQS.exe as was in previous versions of TV.
Edit 2: It looks like it download logo and configuration file TeamViewer.json from web. Difference between original and custom QuickSupport startup time is too high, please add posibility store these infos inside .exe as it was in previous version of QuickSupport.
2) Language problem: I have on your website set language Slovak (environment) but QuickSupport always create English quicksupport executable. There is no setting in management console for target language.
Edit: inside downloaded file TeamViewer.json is settings was this property "language": "" - it's empty, therefore it set defualt language to English. Where i can set this language? I check whole management console but nothing.
