I've been unable to use TeamViewer since Friday - the status only shows "Not ready. Please check your connection". TeamViewer was working fine (version 13) until then. So far I've tried uninstalling and reinstalling, checking for entries in HOSTS, flushing DNS, stopping and restarting the service, as well as turning off firewall and setting TeamViewer to use no proxy (I don't have one anyway), and trying to connect via different ISPs (local wifi, via Verizon hotspot, and via AT&T hotspot on phone). I've tried using both the installed version and the portable version. This is on Windows 10, updated with most recent updates. IPv6 is *not* enabled in networking (but that's not a change - hasn't been for a couple of years w/o issues). TeamViewer on my Android phone connects fine using both the AT&T cell network and my local wifi.
Two lines from the log file... not sure if they suggest potential problems?
CProcessCommandHandlerMasterConnect[326]::ReceivedMasterResponse(): Received MasterCommand BLOCKED
CKeepAliveClient::HandleLoginUserAnswer(): ID is blocked
I've spent hours browsing the forums and knowledge base - I'm out of other ideas.
I've tried logging a support ticket from the support page, but I only get the error: "There was an error in processing your data. Please try again later." I've been trying for hours.
https://status.teamviewer.com/ doesn't indicate any issues with either the website or the TeamViewer servers.
Does anyone have any suggestions?
