Portable Versions (testet with v9 and v11 as v12/v13 are totally unusable) have the problem that mouse clickability from the supporter-PC does not work when using "system- oder admin-related" tools with Windows.
Examples: using "testdisk" from cgsecurity.org is only possible with TV-installed, not with portable. cgs-td can be started from far, but as soon as it is open, the keyboard does not do anything anymore, and also no mouse-click is possible anymore. This lasts until the supported PC makes invisible the window (closing is not necessary, just "sending it to the bottom taskbar" makes remote clicks usable again. Same things with getting task manager or inside the task manager etc.
