I tried this already and it is not fixing my Problem. https://community.teamviewer.com/t5/Knowledge-Base/High-CPU-usage-on-remote-side-of-TeamViewer-Connection/ta-p/9172
A remote client is using about 30 % CPU permanently, also when I'm not connected to this client :-(
Can someone help?
I have a similar if not the same problem. A few months ago with both Teamviewer and with Windows Remote Desktop my remote commuter (an HTPC hooked up to my hifi system) used to have a CPU usage of approx 4%.
Now withTeamviewer the remote PC has a usage of 25% while when the remote computer is accessed instead with Windows Remote Desktop it is still 4%.
Thanks for any ideas on solving this issue as Teamviewer is a far better way to access my remote PC than the generic Windows solution.
