A week ago when i installed TV both on my home PC (behind a router) and on my work Laptop - it all worked fine. I could log from the laptop at my workplace onto the PC at home. Even after the sessions expired i just clicked to connect again and all was fine.
At some point after my lunch break the session had expired and after i clicked Connect again - no success. I dug around and decided to use unattended access password on my home PC. Well, no luck, the next day from my workplace - I was unable to connect at all. Reinstalled the TV on both devices and used default settings - no luck.
Everytime when i try to log onto my home PC, the laptop just says connecting and nothing happens. I see the PC at home is online, but that's it. It doesnt even receive messages when i type them.
I tried to connect from my phone - same result - just connecting.
In the mean time, when logged onto my PC at home, i am able to connect to my laptop at work.
Additionally, when i took the laptop home i was able to connect to the PC (same LAN).
Reinstalled again - same situation. Default settings are applied (as confirmed already).
Any advice?
