Good day, there are 3 laptops with integrated graphics Intel HD 520.
As soon as I connect to them on the Teamviewer, the inscription on the screen flashes periodically that the image at the moment can not be transferred. Further, if you try to open the context menu of the desktop, it does not appear, just in some programs, when you click on the icons, nothing happens, although the context menu should also appear.
If you go into the device manager and delete the driver on the video card, leaving only the standard system driver with a small screen resolution, then the computer starts working without fail. Updating the driver through the Update Center or the Intel site, everything returns.
This problem has been noticed since version 11 of Teamviewer and only on integrated video cards.
