my computer online and i cant login with other 1 i can login with my computer to any teamviwer but no1 can login to my pc help me pls
up. any help ?
Are you trying to connect via TeamViewer to your device, starting from the same device? Did I get it right?
Could you better describe your scenario? You have two different PCs:- connected to the same network?- not on the same network but connected to the internet?- Are both active, online and connected to TeamViewer?- do they have the same version of TeamViewer, or do the caller have a more up-to-date version?
no work , and i see in my friends option same like me and i can connect
but when i try connect to my pc cant ...
Change value to "Accept".
Go to main panel and refresh your password (icon near your password field... probably it's empty now).
Ask someone to connect to you.
Enjoy.
Regards.
how i can fix this
...this is the reason why no one can connect to you.
Hi @itaymalka12,
check your options: Extras -> General -> Incoming LAN connections. What value is it reported?
