The file is edited locally but the printer is attached to another PC remotely. The issue is that i cannot find the printer on teamviewer even i can connect the remote PC via teamview.
Hi @kenchen,
this is the manual that explains how remote printing works. It basically allows you to print a remote document on a locally connected printer.In your scenario there are 2 alternatives:- reverse the sense of assistance so that the client can see your printer as a local and print on its own initiative (using the special button of TeamViewer);- set up a CUPS print server and make it reachable from your location; then add the printer connected to your server as a remote printer from your operating system (without using TeamViewer)
