two-factor verification does not workhttps://youtu.be/9rd-bMTAeW0Fortunately, I was still logged into the browser and canceled the two-factor verification immediately
**Removed By Moderator**??? :smileymad:
Hi Honza1616,
Is the time on your phone absolutely correct?
2FA is not a connection between TV and the app. Instead it uses a time-based algorithm to make sure it is displaying the same code as we accept at the same time.
If the time on your phone is even a minute out, this will not match
Also, this is why we have recovery codes. And evn if you were logged in, you would still have needed a 2FA code or Recovery code to disable 2FA.
-Scotty
See what's new at TeamViewer
