On 2 different Windows computers I have to double click on every Icon or menu in order to get activated I am not sure why ( there is no setting in TeamViewer)
I'm experiencing this problem now on version 15, Windows 10 up to date on both computers. How to fix this?
Hmm, too bad that Teamviewer 10 effectively would be killed by some other changes elsewhere. The money isn't the problem; the rental license model is :-) well, time to move on.
I am sorry , but I double it will be fixed as they are on version 13 , soon 14 is coming.
I understand license fee is in question I own 11, and 12 but I had to move to monthly as of 13
Any news whether Teamviewer 10 will be fixed to for the introduction of needing double click to achieve a single click on the controlled device?
We can't upgrade since the original perpetual license variant is no longer available in NL.
Same problem with Teamviewer 10.0.47484 on controlling side and Teamviewer Quicksupport 10.0.43879 QS on site connecting to. **third party content** works fine. Not through RDP, although it is a server and another user is logged in also through RDP.
I am having this issue with Teamviewer 11 as well so I just updated to 12.0.71503 and I still have the issue.
The problem seems to be solved in the latest beta 12.0.71077.
It looks like i have reported the problem about a week ago (can not remember - really ).
A few minutes ago I got an email from support, that i should try the latest beta. I've just installed it and after a short test it looks like everything is fine again.
Thanks TeamViewer
Same problem here. Pretty much exactly how you describe. I've noticed (at least for me) that clicking in general doesn't work unless I (very slightly) move the mouse after clicking. This is happening when I connect to a Windows 7 or 10 PC using either another PC, or mobile device.
This is very frustrating, and is now keeping me from even using the software. I'll be moving on to another remote desktop solution until this gets fixed.
Note: I've been experiencing this on TeamViewer 11, and 12 beta
I have the same problem on TeamViewer 11 & 12 betaI need two clicks (not doubleclick) to do one click, there is no timeframe when these two clicks need to happen, it's only important to not move the mouse too far. Due to this behavior only single clicks work, double clicks are impossible.
As far as i can see, this happens between the two computers i use most of the time - other computers i connect to from these two computers seem to work normally. The problematic computers don't have this problem under all circumstances, but as it is difficult up to impossible to use the computers, it's very difficult to find out when exactly it works and when not.
Seems to have been for the last 2 or 3 weeks, when i try to double click i either select the icon or something else sort of random happens. I'm not able to just double click like i was sitting at the machine, as i've been able to do for years using teamviewer
i'm experiencing th exact same issue here - teamviewer 11 and 12 - no difference. I always need to double all my click to have the action being performed on the remoted computer...
Hello
Sorry but how can I send you a picture of double click?
Every time i logged into a computer with team viewer ( 2 different Windows 10 computers) I cannot perform any action until I double click on an link, email . other computers its single click ( I have checked windows setting its on single click even when i use the computer in person, but when i access it via Team Viewer I have to double ckick for everything ( even control panel / settings)
Hi Kunsten Tech,
Thank you very much for your post,
Could you please provide us with further information regarding the issue you are experiencing? You also can send us a picture, it would be higly appriciated.and very helpful.
Thanks again.
See what's new at TeamViewer
