Using keyboard combination shift+T when I work by remote control direct into my office workstation by a 3D software (light wave) the command not responding to real input that happen if I work directly by workstation. It’s not a 3D software bug ‘cause happen only by remote control.
Just tried to uninstall and install more times teamviewer 14 in window and MacOsx but the bug isn’t fixed yet.
Are there any suggestions about it?
Is it possible that the last 14 release made the bug?
Best regards
Michele
