I recorded a session properly with Teamviewer. Now, I want to watch the recording by double-cliking on it but it doesn't start.
It works fine when I use the menus in Teamviewer itself but not with a double-click.
I verified the settings in Windows for tvs files association and default programs but even though the icon is Teamviewer, it doesn't work.
Is there another possible solution for that or do I have to use the menu from now on?
Thank you (Teamviewer 9.04xxxxx)
