After installing the latest windows 10 version from April 10th I can't connect anymore. TV says that I might use a proxy, which I'm not. After disabling proxies in the options it says ready to connect but gives no ID and password and I'm not able to connect to other devices.
Thank you once again for your patience and understanding related to today´s connectivity issues with TeamViewer service.
I was talking to the engineering team about it and wanted to summarize this for you to keep you updated:
We apologize for any inconvenience that you may have encountered during this time. I can assure you that our engineers have worked diligently to ensure that performance is fully restored and thanks to their thorough efforts, the issue has been fully resolved.
We continue to work continuously to provide our customers and free users with efficient and reliable software. The whole team spares no effort to make sure that our software runs smoothly and stably for all of you!
Thanks again for your patience and thanks for using the TeamViewer Community to get up-to-date information and for getting in contact with us.
Best regards,Esther
As this thread discussed the connectivity issue from April 11th, 2019, I am going ahead and close this thread.
Thanks!
Esther
Hi @larsoh
Thanks for your suggestion.
You can always try to ping master1.teamviewer.com till master16.teamviewer.com.
I hope this info helps you.
Best, Esther
I have stumbled many times on the situation when different SSL based services/programs stop working or stop connecting. Many times restarting (switching off then on) SSL/TLS protocol filtering in ESET was sufficient. Probably there was something with certificate installation and using this reinstalls the certificates and things start to work again.
So, restart SSL/TLS filtering if things stop working.
Thanks for solving the issue!
May I suggest giving the client an extra way of checking internet access (pinging some known DNS for instance), to avoid blaming not reaching your unresponsive servers on lack of internet access?
Thank you Esther. Clients are now working here in the UK with "Automatically Detect Settings" enabled.
Exactly. I thought my dns crashed, then called internet provider just to be sure :P Last thing to check is if TV is down )) Well.... good job gettin us back online Teaviewer Team is the best!
I can confirm that this works! Just tried on 2 of our laptops we hadn't fixed. Fantastic job guy's and gals :-)
Cheers, Björgvin
Hi @Esther
we are glade to report that TeamViewer 14 is now up and running from our side in South Africa.
again thanks for the support and keeping us up to date.
Hi @Philipppp
thanks for reporting the issue with and to all the support for everyone.
I didn't even think to check, its 'never' down..... ;-)
I'm back online now :-)
Good news from the devs:
We fixed the issue and we are monitoring the results. It looks good so far.
Please confirm.
Thanks, Esther
here also working ...
Meanwhile both my computers are connecting to teamviewer, my customer stil has no connection. I suppose they will have connection soon, so we can resume.
I hope you guys will have this finally sorted now. There have been a lot of failures these last few weeks
Good News
My Teamviewer ver 14 is now working
Thanks a lot for your feedback @Bjorgvin ! My team and I appreciate this a lot and we promise to keep you updated here in our Communities and on our Social Media Channels!
Good that we can still find some positive things on this busy morning :-)
Thanks again to all of you for your patience and understanding!
I keep you posted!
Version 14 is stil not connecting, not on MacOS nor Windows
I just want to give you, Teamviewer gang and especially @Esther for keeping us informed, BIG thank's for your awesome response to this problem and how quickly you started responding to us and trying to solve this :-) Also a BIG thank's to @Philipppp for identifying which Microsoft Update package that's the root cause of this. We are only about 300 users here so this didn't give us as much problems as the bigger company's. We are up&running after we told users to check "No proxy" settings.Cheers from Iceland,
Björgvin
Thanks, @Philipppp !
It´s fantastic to hear that TeamViewer is working again for you.
I just got an update from the devs:
"We are still working on the complete resolution of the issue to get everyone back online. We are seeing good results by sending more and more traffic back on our network. We will update our status page with new information as soon as possible."
While this is not yet the resolution, I am confident that we are on a good path!
I appreciate any update/feedback from you guys about your current status and findings whether you are able to work again!
Thanks again and sorry for the issue!
I have not changed anything and it works once in two .... so already better but not yet fully resolved
14 is still not working, downgrading to 13 works.
But I cannot connect to my already upgraded clients. This is causing me lots of troubles.
It's not acceptable 1 entire morning completely cut off from my work
SERVICES ARE DOWN as of today. Look at https://status.teamviewer.com/
I already had no proxy set...
Setting to "no proxy" resolves the issue for me with TV 14 and my clients using Quick Support
At least for me it works for some reason now. Didn't change anything on my side.
@Esther Thanks for the support
I wait for some others forum members to confirm until I confirm the solution on this thread.
I Return back to Teamviewer 13 and it works
so the teamviewer 14 with new update from windows 10 is the problem
but i need teamviewer 14
cause i can not connect My Clients having ver 14 and my teamviewer is 13
Thanks SFFS, i've just experienced this problem with the latest version 14.2.2558 of Teamviewer.
No proxy server being used, no internet connection problems. I changed my network type from 'Private' to 'Public' in Windows 10 and Teamviewer was instantly connected. Weirdly enough, i changed it back to 'Private' afterwards and its still working, so must be a bug in the latest version of Teamviewer!
Update :
I spoke too soon, its stuck on 'TeamViewer is starting, Please wait.....' and 'Not ready. Please check your connection'.
Hmmmmmm..... None of my software has changed, what's going on?
This is just happening a bit too often the last few days for my liking !
HI @FleetSupport
Thanks a lot for the info. I am passing this to our devs!
Thanks and best, Esther
@Esther
I have found that the latest Windows 10 update (17763.437 windows10.0-kb4493509) is cause the issue with TeamViewer 14 as once the update was applied l found TeamViewer 14 not able to connect, but if you downgrade to TeamViewer 13 it works with no issues.
Hope this helps
hello ?? is anyone going to answer my question ? im still trying to get the hang of this whole this teamviewer business and im not exactly sure what to do next so i can use the app better
