I decided to use teamviewer to access the old netbook running windows XP from my Maviricks Computer... When I needed to access my scanner which works 100% but not on new-ish OS's because the manufacturers did not make updated versions of drivers for it... I then get this depreciation popup message to force update the software... Updated it on Mavericks... everything went fine...then I decided to update on windows XP... cant connect,.,, says my mavericks version needs to be updated... I just updated the darn thing...
Please fix... I have dissabilities... and this is like discrimination forcing me to go up and access the other computer manulaly is just no on.. beig forced to wait 5 minutes in the middle of the scan just makes my anxeity explode... Its cheesed me off and made me very angry... I had to system restore windows XP computer just to make it work, but those depreciation nag dialoges with forced 5 minutes happen again... Then its doing the same thing with my Snow Leopard machine, cant even update that as well as it says its at its latest version... so what is the fuss ??, and I need it to work when I am going on holiday to south africa to my parents for christmass to keep an eye on my cat and if the cat sitter comes in everyday to feed my cat !!!!
