Hi, I’ve been using the free version of Teamviewer on my Mac to remote to a Windows PC for several months and everything has worked well. Then I decided to turn on Facetime and now I have problems.
Now it takes 5-30 minuites to connect. The Teamviewer box on the PC pops up immediately like it's connected but nothing happens on the Mac for the 5-30 minutes. Also, once I start Teamviewer on the Mac, I can longer use Facetime or even get into System Preferences. It seems to be stuck on Authenticating,
I can re-boot and everthing will be fine until I try to run Teamviewer again. Then it starts all over. I've turned off Facetime, and re-installed Teamvewer but nothing works. Any ideas? Thanks.
