Start connection in fullscreen
Hi everybody,
I'm trying to build a LAN based ThinClient-style usage of one PC beeing host and another mobile one beeing the controller of the other one (both win10 atm, ThinClient tbd).
So far I'm getting pretty close: I was able to drop a shortcut with the local (IP based) connection parameters in autostart on client side and it's working fine besides one thing: I don't see any option to get the connection default in fullscreen.
Is there a way to achieve that?
Kind regards,
Dominik
Hello @32Domi,
TeamViewer does not open per default the remote session in full screen and there is, unfortunately, no such option to set it as default.
However, the client remembers how the previous session has been closed.
This means, if you are connecting for the first time to a device, put it manually to full screen and close the session. Now, connect again, and the session should start in full screen automatically.
Cheers,
Does not work for me when I close the connection via the toolbar and reconnect. https://superuser.com/questions/639102/make-teamviewer-remember-position-scaling-full-screen
