Hello Support
We are using TeamViewer Version 15 and for some time now we have not been able to connect to our clients in a reliable way.
We have discovered the following:
- The user opens via Intranet our TeamViewer QuickSupport. Either it takes some time until the ID is displayed or an error message appears that the Internet Connection should be checked. The Internet Connection is fine.
- If an ID appears at the client, it takes a long time until the connection to the partner is established or the connection is terminated (Initialize connection parameters). Sometimes 3-4 attemps are necessary until the connection to the partner is established.
- In addition we have found that version 10 of TeamViewer QuickSupport is much more better performing that version 15 of TeamViewer QuickSupport.
Now the questions:
- What must be configured on the Firewall (Ports, FQDN, IPs) etc.. to run TeamViewer with a stable performance?
- Why does an older version of TeamViewer QuickSupport (version 10) work much better than version 15 of TeamViewer QuickSupport?
I would like to thank you in advance for the answers.
Kind regards
nmoreira
