Firefox starts, but is only a white box.
Haba
Haba Posts: 2 ✭✭
When I start Firefox via TeamViewer only a white Box appears. When I click the right locations, it works, but everything is white. Also window titel bar with buttons to hide/minimize/close.
Without TeamViewer Firefox starts normally.
Hardware: HP Z440 WorkStation, Windows 10 Pro, NVIDIA Quadro P4000 (375.86 ISV-certified driver)
Already tried:
 - install different graphic drivers
 - install different Firefox releases
Thanks!
  • PierreLemaux
    PierreLemaux Posts: 5 ✭✭
    Did you try to desactivate the graphic acceleration in firefox option?
    I have also two quadro in sli, I resolved the problem with firefox but I have the same problem with 3dsmax if I'm using nitrous driver...
  • Hupf
    Hupf Posts: 1
    Whenever at least one monitor remains physically connected to the remote host's GPU (HDMI or DisplayPort cable), Firefox renders correctly over TeamViewer. If I disconnect the last monitor cable, the existing Firefox windows are no longer responsive/refreshed and new ones render as white.
    This is with most recent Firefox and Nvidia
  • BoHu
    BoHu Posts: 1
    We have here the same problem with a Lenovo and a Intel HD Graphics 620,
    I try from cmd Firefox -save-mode this will work,
    but is no soultion because we need the plugins
  • DINK74
    DINK74 Posts: 1
    Had the same issue on Lenovo ThinkPad T440s with Intel HD Graphics 4400
    Last night - after installing Windows Feature Experience Pack 120.2212.31.0 the issue "repaired itself" and now FF 79.0 looks as expected
    Windows 10 Pro 64-bit
    Version 2004
    OS build: 19041.450
