Quick support on Samsung tab pro not supported
Galaxy tab 10 pro running on Android 7
Screen sharing not supported.
Any idea?
Regards, Paul
  • pmeijers
    Android 7.1.2
  • TotalPC
    TotalPC Posts: 87 ⭐Star⭐
    Hello @pmeijers ,
    Along with the base QuickSupport app: https://play.google.com/store/apps/details?id=com.teamviewer.quicksupport.market you will also need to install this add-on: https://play.google.com/store/apps/details?id=com.teamviewer.quicksupport.addon.samsung the base app should alert you to install this if it's not already installed.
    Also, Knox, Samsung's security platform, must be activated.
    More information can be found here in the community. This article also has a Universal add-on which in some case will fix issues.
    Hope this helps. If not, do you have any more details?
    -Cheers!
    TeamViewer user since version 6 (2010). We used other remote software programs (TVNC UVNC PCAny) for many years before.
  • pmeijers
    Hello @TotalPC ,
    During installation i am not prompted to install the add on.
    Also Knox is not installed.
    Note: i am running LineageOS 14.1 which is Android 7.1.2
    Note 2: the other way from tab to phone works fine.
    Any suggestions?
    P.
