Changing IDs
Hi
I have a problem with changing IDs on my hosts. Its any solution that computer keep IDs ?
In console i have a lot dupliacate hosts..
    Hello @IIIT,
    We currently have an issue with the Windows 10 v2004 update. This might cause the ID change when updating the devices. You will find more information here: Teamviewer ID Changed after upgrade windows 10 2004 version (May update)
    We are sorry for the inconveniences caused.
    Best regards
  • IIIT
    IIIT Posts: 7
    Hi
    Please tell me , if i will reinstall Windows or install fresh one ,on the same PC with same NAME.
    Did ID will changed ?
    @IIIT  If you revert it to a previous Windows version (e.g v1903), the ID will change to the initial one.
  • IIIT
    IIIT Posts: 7
    Ok, Did TV plan fix it in v 2004 ?
    Hello @IIIT
    Yes, our teams are currently working on a resolution that we be deployed as soon as possible.
    Best regards
