I was able to update to version 12 remotely without issue but ever since BETA 13 was an option, I have never been able to update remotely.
I was told to ensure port 443 is open - it is. That's all support told me. It still won't work.
The problem isn't resolved. The latest version (.81460) has the same issue on some computers. Downloading the installer and manually install works but updating remotely doesn't.
I've had 78716 for a while and the issue seems resolved. Haven't had any problems remotely updating.
Be patient and give the people the time to put the new version on the update-server!
Version 12.0.80984 has been released today....
So what was the resolution to the problem? I see no newer version to 12.0.78716 and I still have the issue of not being able to remotely update.
I think, I have the possible reason for this issue:
I just updated two PCs in Italy (my brother and my sister :smileywink:); they run the free full version (not the host) and the remote update was running without issues; on the other site on a laptop in my home network was not possible, I had to go to that laptop and upgrade manually.
Also my opinion is that the host-installer version 12.0.78313 has a bug and is not able to download the new version (see my previous post).
I sent a mail to the support guys.
I tried updating manually at several machines onsite and none of them worked. Same problem on all! I'm just hoping Teamviewer fixes this in a way that doesn't require going onsite.
Same issue here!
The hint in the LOG-file refers to a connection-problem with the download-server
Updating manually at the computer works.
Correction in my last post. I meant to say "problem ISN'T just trying to do it remotely" ...
It seems the problem is just trying to do it remotely. I was at one of the client sites yesterday and it doesn't upgrade even when you're there doing it direclty! I'm getting more and more frustrated with TeamViewer, bugs not being fixed and almost impossible to reach support. And even when you do reach them stuff like this doesn't get resolved. I spoke to a rep for a long time about this on Thursday and everything they suggested made no difference whatsoever. I may not renew with them and will start looking for another product if it doesn't improve!
Wouldn't mind but this isn't the first time these problems have occurred! I had to log in with another remote software and manually install the newer host version.
Not great... as a fee paying customer this shouldn't really happen.
Same issue, but also does not work when I RDP into server/workstation
Having the exact same issue; Thought it was a licensing issue at first.
I'll work some more on this, over the weekend and let you know what I come up with.
After updating to 12.0.78716 when I connect to hosts I'm not able to update them as well. Clicking "check for new version" does respond that there's a new version 12.0.78716 and that the current version is 12.0.78313HC but when it starts to say "downloading ..." but then pops up with an error message saying "an error occurred while updating teamviewer ... check log file". Checking the log file doesn't seem to provide very useful information. This is happening on all of my hosts located in completely different places. They all have my host module which I haven't changed at all and it always worked before including very recently. The only thing changed at my end is the upgrade to 12.0.78716. I tried a number of things suggested by support but nothing resolved the issue!
