MSI deployment and account assigment without easy access
How do I assign my devices to Teamviewer Account without granting easy access via MSI and CMD/Powershell?
How will it work with GPO?
Gintaras
Hello @Gintarasp2,
In order to deploy TeamViewer without Easy Access, you only need to make sure that you don't add the Easy Access parameter in your command line.
Here are two examples:
Without Easy Access
msiexec.exe /i "<Path>\TeamViewer_Host.msi" /qn CUSTOMCONFIGID=<Your_Config-ID> APITOKEN=<Your_Apitoken> ASSIGNMENTOPTIONS="--alias %COMPUTERNAME%"
timeout /t 5
net stop teamviewer
net start teamviewer
With Easy Accessmsiexec.exe /i "<Path>\TeamViewer_Host.msi" /qn CUSTOMCONFIGID=<Your_Config-ID> APITOKEN=<Your_Apitoken> ASSIGNMENTOPTIONS="--alias %COMPUTERNAME% --grant-easy-access"
timeout /t 5
net stop teamviewer
I hope this could help. ?If not, do not hesitate to ask your questions here. ?
Best regards
Hello JeanK, That is what I used to do to enroll device with --easy-access.
However if I use you suggested line:
timeout /t 5
net stop teamviewer
I wount not get device assigned to account:
https://ibb.co/x6xWt2t0 -
Hello @Gintarasp2
Thank you for your message. ?
As this is not expected behaviour, this needs to be analyzed by our engineers.
I recommend you to open a ticket, our engineer team will be happy to look at your logs and help you further: https://support.teamviewer.com/a/
Best regards
