Unable to hear sound from remote computer
I've got TV 15.11.6 on my work and home PC - both are Win 10.
Work PC is Windows 10 Enterprise 2004 (OS Build 19041.630)
Home PC is Window 10 Home Version  20H2 (OS Build 19042.630)
When I connect from my work PC to my home PC, I cannot hear the audio from my home PC.
This worked until I had to do a Windows reinstall
    Hello @ALibertarian,
    It could be the case that after your OS reinstall, some system drivers were not updated/installed.
    I'd recommend you to check if the audio drivers of your device are installed and up-to-date.
    Best regards
  • ALibertarian
    ALibertarian Posts: 2 ✭✭
    Since I'm working from home since the pandemic, the "remote computer" isn't really remote, just in a different room.
    The sound plays normally through the laptop speakers and, if I plug in a USB headset, the sound plays there also.
    Thanks for the suggestion
