Hi everyone, Hi @_Andreas_ ,
Does anyone know if the Teamviewer client now works on Mac ?
Everything is installed correctly on mine but the client does'nt launch.
Thanks.
Patrick0 -
For now, is not working to connect from a MacOS to a Synology device.
Mircea
Tech Support IoT
When will macOS be supported?
hi @PatrickG
I have the following problem when connecting thru Teamviewer to my NAS DS220+.
I have installed TEamviewer on NAS and successfully established the connection thru Teamviewer client to the NAS. But there is a security issue poping up when connection (see pic below), that says that the name on the certificate in invalid or does not match the name of the site. I assume this means that the connection is not secure when connecting thru teamviewer because of the issue with certificate. My certificate installed on NAS is valid and issued by Lets Encrypt. I can actually connect, by its not secure. Would appreciate if you could help me make the connecton secure.
Can u pls furnish me with the solution what to do in order to pass this certificate issue successfully? thx
Simon
On my Synology DS215+ dith DSM version DSM 6.2.3-25426 Update 2, TeamViewer doesn't work.
It has never worked.When I run it, it shows a blank little window wi no links or button except for the "Third party licenses" and "www.teamviewer.com" links on the bottom.
Any ideas on how to fix this? It used to work but presents blank screen after update:
Hi @mahisri
The device is assigned to your account or because the interface is not loading you were not able to do it? I am asking this because if is not assigned you can try like a quick fix if it is possible via the “Nearby contacts and devices” function for adding the device.
On some devices it seems that the Agent interface is not loading, we are aware and trying to fix it.
Tech Support IoT
After almost a year, still no news with TeamViewer 15.15.5 on Linux! :-(
Connecting to TeamViewer IoT on a Synology NAS results in "Authentication rejected".
Hello everyone,
I'm facing problem with Teamviewer package on a Synology DS220+.
When attempting to "Assign" my NAS to my Teamviewer account, i have this message :
Even with the correct password for assignement, i get this error.
For information, i have already added 2 other NAS, DS220+ and DS118 without any problem !
I'm thinking that it comes from the package ...
Any idea, please ?
Thanks in advance !
I could add my NAS by using Teamvier from my PC and use the “Nearby contacts and devices” function 😀
I am also getting the same issue with the blank box. I have never installed the app on the Synology. The local search method on my windows machine finds the server, but, I cannot login as I do not know the password nor have been able to link it to my Synology account :(
Anyone have any ideas to make it display? I have tried checking & unchecking the security box - cross site protection.
I am running: Synology DS214 (MARVELL Armada XP MV78230) running DSM 6.2.4-25556. TeamViewer 2.8.17 version on Synology
On some Synology devices seems that the TeamViewer Agent is showing a blank page.
If you are in the same LAN network with the device, open on the PC TeamViewer and try to add the device via “Nearby contacts and devices” function.
The device will get assigned to your account without the need of password. If the device is already added please try again to add.
Mircea
Tech Support IoT
How the teamviewer app on synology could be reseted?
Whats the path of the Settings File?
Because only delete and reinstall the app is not solving my problem.
Hi! There is a Synology NAS with TeamViewer 2.8.17 installed and there are also problems with its operation. More precisely, it does not work at all. I launch the application, White screen and nothing else. It stops. I also attach a log file. I reinstalled and did a full reset, the HDD faded, with no result. The rest of the functionality works fine. And how can you then want to buy a license :( DSM 6.0.2-8451 The previous version 2.3.7 starts and works fine, but you cannot connect to it - it requires updating the application to synilogy NAS. 2021/10/27 20:00:25.844 15727 1074823168 Logger started. 2021/10/27 20:00:25.873 15727 1074823168 Found 4 stack dump files ... 2021/10/27 20:00:25.873 15727 1074823168 Found 4 Minidump files ... 2021/10/27 20:00:25.933 15727 1074823168 ! AsioSettings::FindExternalIP: found 0 external IPs instead of 1! 2021/10/27 20:00:25.979 15727 1074823168 ! AsioSettings::FindExternalIP: found 0 external IPs instead of 1! 2021/10/27 20:00:30.801 15727 1074823168 IdentityManagement: Load ManagerIDs from local Storage: 2021/10/27 20:00:30.803 15727 1074823168 [Beehive] Initializing Beehive device 2021/10/27 20:00:30.806 15727 1074823168 !! DeviceBaseLin: Initialization of the device failed, Errorcode=2 2021/10/27 20:00:30.806 15727 1074823168 !! BeehiveDeviceFactory: Synology Device initialisation failed, Errorcode=2 2021/10/27 20:00:30.807 15727 1074823168 !! [Beehive] No device information available!, Errorcode=2 2021/10/27 20:00:30.807 15727 1114630560 NetworkControl shutdown started 2021/10/27 20:00:30.808 15727 1074823168 NetworkControl shutdown done 2021/10/27 20:00:35.814 15727 1074823168 !!!Crash: stack dump has been written at '/volume1/@appstore/TeamViewer/logfiles/teamviewer-iot-agent_BV_15.3.17_2021-10-27-200035.armv7.stack', Errorcode=2 2021/10/27 20:00:35.864 15727 1074823168 !!!Crash: Minidump has been written at '/volume1/@appstore/TeamViewer/logfiles/teamviewer-iot-agent_BV_15.3.17_2021-10-27-200035.armv7.dmp', Errorcode=22 2021/10/27 20:00:35.864 15727 1074823168 Process received fatal SIGABRT
Hi @Amsterdamer
Could you please try to assign the device via the "Nearby contacts and devices" function from your pc's TeamViewer application and see if is working? The steps are here
Mircea
Tech Support IoT
Of course, I tried it beforehand. I just attach a log file. How will it be detected if it crashes when the application is launched? and yes, the proposed solution does not work, as did my predecessors in this thread. Are you sure you read my post completely? No offense :)
Hi @Amsterdamer
It is possible to sent the model name of your device and the entire logs from the agent?
Or the above lines are the only ones?
Mircea
Tech Support IoT
Yes, the only ones, he just can't write anything to the log. DS214se
These are all logs, they are repeated with each attempt to start the application. I don't remember the model, 2 is wild on the Marvell Armada 370, like DS213j
2021/10/27 20:22:29.245 6694 1074126848 Process received fatal SIGABRT
2021/10/27 20:45:31.529 10539 1077088256 Logger started.
2021/10/27 20:45:31.579 10539 1077088256 Found 6 stack dump files ...
2021/10/27 20:45:31.583 10539 1077088256 Found 6 Minidump files ...
2021/10/27 20:45:31.636 10539 1077088256 ! AsioSettings::FindExternalIP: found 0 external IPs instead of 1!
2021/10/27 20:45:31.690 10539 1077088256 ! AsioSettings::FindExternalIP: found 0 external IPs instead of 1!
2021/10/27 20:45:37.278 10539 1077088256 IdentityManagement: Load ManagerIDs from local Storage:
2021/10/27 20:45:37.279 10539 1077088256 [Beehive] Initializing Beehive device
2021/10/27 20:45:37.280 10539 1077088256 !! DeviceBaseLin: Initialization of the device failed, Errorcode=2
2021/10/27 20:45:37.280 10539 1077088256 !! BeehiveDeviceFactory: Synology Device initialisation failed, Errorcode=2
2021/10/27 20:45:37.280 10539 1077088256 !! [Beehive] No device information available!, Errorcode=2
2021/10/27 20:45:37.307 10539 1123518880 NetworkControl shutdown started
2021/10/27 20:45:37.307 10539 1077088256 NetworkControl shutdown done
2021/10/27 20:45:42.334 10539 1077088256 !!!Crash: stack dump has been written at '/volume1/@appstore/TeamViewer/logfiles/teamviewer-iot-agent_BV_15.3.17_2021-10-27-204542.armv7.stack', Errorcode=2
2021/10/27 20:45:42.470 10539 1077088256 !!!Crash: Minidump has been written at '/volume1/@appstore/TeamViewer/logfiles/teamviewer-iot-agent_BV_15.3.17_2021-10-27-204542.armv7.dmp', Errorcode=22
2021/10/27 20:45:42.470 10539 1077088256 Process received fatal SIGABRT
I can connect to my Synology DS718+ using Teamviewer from my pc with no problem, but when I try from my Android Teamviewer app, I get a message saying "This remote device doesn't support screen sharing. Contact support"
It seem that the connection relies on the Synology ports to be 5000 & 5001 but I have changed mine to 5011. Is there a way to change the logon port in Teamviewer? Port 5001 gets my web station on the Synology
TeamViewer should pick up the changed admin port automatically. Did you try restarting the TeamViewer service or the Disk Station? If that does not help, please contact support with the logfiles attached.
NAS Synology DS720+ with DSM DSM 7.1.1-42962 Update 2
Teamviewer app version 2.21.16-7004 installed on the NAS
Teamviewer version 15.35.7 installed on my Windows 11 Pro Notebook
Can't connect to the NAS, says "connection not established" "Authentication rejected"
How to resolve?
