Teamview Host on Android Lockscreen
I'm trying to remote control an android device having Teamviewer Host running via Teamviewer running on a Windows 10 PC. After the connection is established, the lockscreen of the android device is shown and I have to type in the PIN. How can I do this on the PC. Using the keyboard doesn't work. The android device is OnePlus 6 running Android 10 (Oxygen OS 10.3.1). Can you help?
Best Regards
Thomas
  • I have the same Problem with the same One+ Device with the same Android Vesion. I tryed Windows 10 Windows 7 and other Android devices to get remote access. Every time the same I don´t see pin Pad an the one+. But when I press on "not visable screen " the one+ reacts an gets  the randomliy pressed number.
    For me it´s interesting, that I can up- and download files to the one+.
    Pleas help,
  • ObiYawn
    ObiYawn Posts: 2 ✭✭
    I see the exact same lock screen on three Android 10 devices. These devices are pattern locked. I can't find a way to enter the pattern -- I always have to ask the user of the device to enter the pattern directly on the device itself before I can gain access remotely.
