Good luck getting a resolution on this. I too am using TeamViewer on one PC in my home, and they are claiming that the software thinks I am working at a corporation or something. I have been sent in multiple support tickets and I'm now 2 weeks into trying to solve this problem on ticker #2811876.
I am no further along that I was two weeks ago. Support requested my logs, then they disappeared.
Not having access to TeamViewer has made my life much more difficult, and I'm sure it's the same for other people, but I absolutely refuse to pay $849!! for a single user license for home use.
I hope you have more luck with this than I have. Sorry I can't be of more assistance.
Hi Skeeter,
thank you for your contribution.
We have already replied to your ticket, please check your mailbox :smileyhappy:
Reyhan0 -
I own at least 6 personal computers and about 8 family members computers I fix for them, I am not using Teamviewer for commercial use but the app thinks that I am how come?
3 -
Chances are when you installed teamviewer on one of those machines you chose that you where using it for professional purposes or mixed use. Once you do that it flags all of your systems that are on your account with it. To my knowledge I am not sure how to undo that. Maybe talk to TV support?
Bart Lanzillotti
We Do IT USA
www.wedoitusa.com2 -
I am in a similar situation, a few own PCs and a lot of family and friends and i have this "issue" everytime i change my "main" computer. After some time i get the message that i'm suspicious to use TeamViewer commercially. This is not a big problem, you just have to contact support, send them the log-files Teamviewer##_Logfile.log and Teamviewer##_Logfile_OLD.log. If you are really not using TeamViewer commercially they will "unlock" your computer und you will not see this message again until you change your computer.
I don't know how TeamViewer identifies potentially commercial use, but i can see that my behavior looks like this, even if it is not the case.
»We are all born unique, but most of us will die as a copy.«3 -
Please, I have to use it, my ID is [ID removed]
When you started a trial, you notified TeamViewer that your intended use is commercial, otherwise you do not need a trial version.
I think but I'm not sure that the installation is somehow marked as "commercial" and you are now trying to return this to "non-commercial" which seems understandably suspicious.
I think you need to contact support to resolve this. I've done this in a similar scenarioBTW you should not mark your questions as solved, the chances are very little that you will get an answer to a solved problem.
»We are all born unique, but most of us will die as a copy.«4 -
I marked as solved for mistake! Thank you for your answer! I think that TV team has resetted my id and now is all ok again!
Hello.
Sorry for my bad English.
I have been using Teamviewer for personal use for several years.But, a few days ago, when I opened the remote connection window, appeared a request to acquire a license because my trial period would have expired.And I can no longer connect between my computers. However, on my profile of my management console, it is always indicated that I have a free license. I never, unless a bad manipulation on my part, asked for a trial period, nor indicated that I wanted to use a professional version. Could you tell me how to find or re-request a free private use? That I can continue to use Teamviewer which I am completely satisfied with.
Thank you in advance. Philippe Jolet.
Clarification.
The trial version is only on one of my computers. It is probable that I made a bad maneuver by installing teamviewer 12 beta then uninstalling it to go back to version 11 because it did not work with my other computers that works in linux. Other computers that continue to communicate with each other. This is simply to be able to reinstall Teamviewer in free version on this computer. Simply ?0 -
Sorry Reyhan, but shouldn´t this answer be published here?
Thanks!
I have done that and even installed the new beta version. I was careful to install the non-commercial version but it still says that my trial version has expired.
I am having the same issue. It looks like once you pick the wrong option, you can never go back.
My account is determing as 'used for business' and what I did was just start a new Android virtual machine on my server which set in my room. It's hard to control that Android virtual machine so I try to use Teamviewer. However, when I connect to this Android device, the program says I was using for business and the connection would be closed in 5 min. That's incomprehensible because everyone could buy some extra devices for their own and I think determine whether the users are using program for business by this way is not clever.
Sorry for the language is Chinese, but you could understand.
I don't know if it is the same problem, but i have sometimes (whenever i change my main computer) a message that i am suspected to use TeamViewer commercially. If this is the case the only way i know to get rid of this message, is to contact support and send them your log-files, so they can check that you're not using TeamViewer commercially.
To let us know the exact message you can change the language of TeamViewer to english temporary. TeamViewer options -> Advanced -> Display language (First setting at the top)
»We are all born unique, but most of us will die as a copy.«1 -
I'm in the same situation, I have a lot of personal computers even some with different operating systems. lots of friends and family members, I sent my log files once, I even asked if I could have a personal licence that is for home users, because I help others without receiving money. I would like to contribute with a mesure payment as a non profit person, but they sent me a quotation from 350 Euros per 50 hours per month and I only use it to help some friends. It's a good product, but saldy they are forcing me to look in other directions. I will probably also recommend the others instead.
2 -
When I had a Business Account I used to get a similar message despite having paid an annual fee.
I seemed to remember resolving it by logging into the Management Console and under the main Account Heading (Large Blue Box) with details of the account, left clicking on the box and selecting Edit Profile.
Within the edit profile dialogue box under the General Section Menu you can makes changes to the type of Licence currently allocated to the device.
Under the Licence Menu you can also manage your licence.
Hope this helps you resolve your Trial Message problem.
2 -
When i try to connect to patner id then this error showing may i know how i can fix this Error see the attachment file.
This is not really an error message. It is normal that after a trial period software will not work until you buy a license.
And I do not know what one can tell you in addition to the content of this message, as it is absolutely clear what to do. Maybe that most of us here, are not TeamViewer. The "us" in this message is either support or sales.
Two hints:
Read carefully when installing software - It might do what you select.
Do not shout "urgent" to someone, from whom you want help.»We are all born unique, but most of us will die as a copy.«2 -
I install this with free not buy or trill for useing.
The message says the host you want to connect to has installed it as a trial, not on your end.»We are all born unique, but most of us will die as a copy.«2
I just submitted a ticket as well. Having the same problem. My account has a commercial block on it. I installed Teamviewer 12 for personal use a month ago and now the application displays a message telling me that the trial period has expired.
I uninstalled and reinstalled Teamviewer, deleted my account, created a new one with the same email, then with a different one, replaced it with a Teamviewer 11 install for private use, but it continues to say that the trial period has expired.
I am using it strictly for personal use. Please help me out so I can use the plain version. Thank you.5 -
Hi Sashaa.
You must have patience and wait for the answer to your ticket.
Math
4 -
Sadly this did not fix the issue for me
I'm attempting to download files from an older computer using an up-to-date Teamviewer 12. However, the session keeps closing saying it has timed out.
On both the sending and receiving computers, "Extras->Options->Advanced->Timing out inactive session" is set to off. Is there anything else I should be doing, or is this an error?
Hi, it seems that by mistake i installed TeamViewer for commercial use, now it's blocked and even if i reinstalled it again, the same message will appear, i have already submited a ticket with and without log files in different dates.
My tickets are: 2920084(without log files) and 2911051(with log files).
I hope someone can help me.
(english a bit sloppy because its not my native language)0 -
Hi CARLOS,
Thanks for your post!
I can confirm that your ticket has been recieved and is awaiting review. I apologise for the delay. As we recieve a large number of these tickets and also need to provide priority support to our paid users, there has been a longer wait time over the holiday period but we will get to it ASAP.-Scotty
Senior Moderator
Did my reply answer your question? Why not accept it as a solution to help others?0 -
Hi. I have this happening. But it is with the OSX version. Is there a link for the proper host for OSX free version? Thanks.
TeamViewer website -> Download -> Mac -> Download Host
And vor v11:
TeamViewer website -> Download -> Zu den älteren Versionen -> macOS (v11.0.66595): TeamViewer Host
