Is there someway to "bulk remove" serveral computers from the Team Viewer Management Console? it's tedious to remove many computers by hand as for now...
Hi All!
This is currently in as a feature request. (Bulk select for actions)
However, unfortunately placing the items in a group and then deleting is not currently doable as groups that contain items cannot be deleted.
I know this is not ideal, but this is the best work around I have:
One of our supporters has also posted a powershell script that will allow you to delete groups if you would prefer. You can find this in our Knowledge Base here
I apologise, I know this is a long way around and I have added your votes to this feature request as well.
-Scotty
Hi SuperDOS,
I do not know if this is the correct answer, but you might try (i suggest you try on a small set of devices).
Create a dummy group;Select multiple devices;Use the button to move items to the dummy group;Delete the dummy group.
Repeat: I do not know if this is the correct answer, but this operation has been requested some times in ideas site, and marked as implemented (??)
thx. :-)
@it4logistics
Yes, they do.
Please read the instructions again as I advised to delete the new account, not the group.
The PS script in the KB article also works on devices with groups in them.
Hi guys,
I cannot see a delete option when clicking Edit profile on the created account.
Any suggestions?
Thank you !
Hi Everyone,
If it helps, one of our supporters has posted a powershell script that will allow you to delete groups if you would prefer. You can find this in our Knowledge Base here
As I said before, this is in as a feature request and being discussed as part of enterprise upgrades, but I cannot change my answer that it is not currently a feature, this is being passed on.
@davidblumwrote: What is MFA :P ?@SuperDOSwrote: The easiest way to make sure you don't have someone by mistake removing a bulk of users/computer is using MFA to elevate this type of execution.
What is MFA :P ?
Multi-Factor Authentication
Would be pretty simple to implment with either a SMS service or Googles Authentication App.
I'm sorry....
This was a feature request before V13 was out months ago... don't you guys have anything better to propose more than 6 months later ?
I have more than 200 rogue computers that are an issue and this happens also for reassigned computers or migrated computers which clone themselves in the process ... (e.g : To a new Hypervisor)...
i believe DEV could consider another way at least in the Web console for a company administrator.... .. The Company Administrator should have a bit more rights and flexibility. to me the statement about Rogue agent is valid at some point but inappropriate if you look at any other decent IT management product on the market...
Hi mallen,
I am sorry you are having trouble.
The solution does work as confirmed by other users above although it is the long way around.
Note that I did not say to delete a group as this does not work. I said to create a new account, then a new group in that account, share and move the devices, then delete the new account - not the group.
In this case, it is not a case of the length of time users have been asking. It's about security. If bulk delete was possible, development is worried that one rogue agent or one mistake could easily wipe an entire contacts list.
This is in as a feature request. And yes, there is also talks of better methods for stopping accidental or malicious deletion but please understand this is not simply a case of adding the feature or the number of times or duration you have been asking.
Trying to remove the dummy group gives an error saying. Please remove computers from the group.
open each computers property and delete that computer from your list
I attempted this method and, when I tried to delete the group, I was greeted with a message that said I couldn't delete the group because it was not empty.
Still have many "unnamed" and really "non-existent" computers showing up in my management console. Would just like to clean them out.
Hi Scotty,
Just wanted to say thanks for this response. I've got 900+ computers to remove and was not looking forward to doing it by hand!
Will give this method a go!
as of today this does not work in corporate web console
@DomLan wrote: Hi SuperDOS,I do not know if this is the correct answer, but you might try (i suggest you try on a small set of devices).Create a dummy group;Select multiple devices;Use the button to move items to the dummy group;Delete the dummy group.Repeat: I do not know if this is the correct answer, but this operation has been requested some times in ideas site, and marked as implemented (??)Regards
as of today this does not work in corporate edition web console
Yes that's a workaround, hope this will be implemented in the future.
Thanks.
