Compatibility with Big Sur
Are there any known issues with connecting to a Mac running Big Sur?
When I connect to my MacBook from my Windows computer (which is next to the MacBook) the connection randomly freezes and the screen stops updating. I can still see the mouse moving on the MacBook, but the display just doesn't update.
I can maintain a connection without issue to other Windows computers in my house without issue for hours.
    Hello @CMTietgen,
    We do not have any compatiblity issues with Big Sur.
    However, what you could try is to use the Refresh screen button within the remote control session:
  • CMTietgen
    CMTietgen Posts: 1
    Sorry it took so long, but the issue isn't resolved by refreshing the screen in the method you mentioned.
    I have tried new network cables and a new network adapter and the problem persists. Once my new switch arrives, I will try again.
    All I know is this issue is only happening when connecting from my PC to Mac using wired connection on a USB-C hub. If I connect via wifi, I don't have the issue.
    That being said, connecting from PC to PC using the same USB-C hub and network switch and cable has no issues.
    And just to be clear, it's only the display that stops rendering. I have the Mac sitting right next to me and I can see the mouse move and do whatever I want. The remove display on the PC just freezes.
  • Quotidian
    Quotidian Posts: 1
    I have the same issue. Unplugging the wired connection and switching to just wifi fixes it, but I need to use the wired connection if at all possible for data transfer.
