My Remote Desktop screen is very small and I can’t adjust it.
    edited November 2021
    Hello @Michael_Ves,
    You can change the resolution of the partner's screen within the TeamViewer toolbar:
  • Michael_Ves
    Michael_Ves Posts: 4 ✭✭
    Thanks for responding JeanK . When I try to access the other resolutions from the pull down menu, there is no pull down.
    @Michael_Ves This means that TeamViewer can only capture one resolution on your remote screen.
    This might be the case if:
    • there is no screen plugged in the remote computer
    • the screen on the remote computer is very old
    • there is an issue/bug with the remote screen
  • Michael_Ves
    Thanks again for your help. I had a full screen a couple days ago when this condition just started happening. Ii just got a new computer with new monitors in December of 2020. I can't say anything about a bug.
    MV
