After reboot: Authentication using fixed password was denied
CBellmann
We have Teamviewer installed on a remote Computer, set up with a personal password.
This works as long the computer is running. But after a reboot, we cant establish a teamviewer-session, on typing in the set password, it displays "wrong password".
The corresponding line from the Teamviewer-logs is probably:
2018/08/30 08:15:54.015 5848 5732 D1 AuthenticationPasswordLogin_Passive::RunAuthenticationMethod: authentication using fixed password was denied
What should we do to prevent this?
Regards, Christoph Bellmann
i have the same problem...
