1213214216218219349
  • Shinx
    Shinx Posts: 1
    I have been using Teamviewer with free license just fine with my family/friend but today when I tried to connect to my friend computer, Teamviewer blocked me saying that "Connection blocked after timeout. Your license limits the maximum session duration to a partner, immediate reconnects are blocked. Please try later of upgrade your license."
    After that everytime I try to connect, it blocks my connection for one minute. If I connect at 15:31, it says "Connections to this partner will be blocked until 15:32" and so on.
  • peval
    peval Posts: 2 ✭✭
    This is strange.
    It happened to me a couple years ago, i had activated the "start at login" Team Viewer option on my windows computer and i immediately received a notification about potential commercial use detected and i could see this notification permanently in the Team Viewer windows.
    Now i see everywhere "free version", so it does not flag any detection
    Is TV support aware of this? do we still need to go for the reset procedure?
  • Heinvomberg
    Heinvomberg Posts: 0 Newbie
    This link wouldn't solve our issues.
    Isn't there anybody from Teamviewer for helping us with timeout issues in free versions?
  • schoofol
    schoofol Posts: 0 Newbie
    Hello I am using the free license (non comercial use only account) until today I had no problem accessing my home computer from my laptop. Today I logged in and then got this message after it logged me out of my PC, "Connection blocked after timeout. Your license limits the maximum session duration to a partner, imediate reconnects are blocked. Please try agian later or upgrade your license".Was there a policy change? I have been using this free account for years with no issues. Thanks for any help
  • Truckeeer
    Truckeeer Posts: 10 ✭✭
    Same here. Timeout after few seconds.
    Server and client are on latest version, Windows to Linux.
  • Same problem here
  • NYBBLER
    NYBBLER Posts: 0
    Even thou the option is off I keep getting kicked from my session after a minute or two. Every update they release has a new problem that doesn't get solved
  • jhchoi
    jhchoi Posts: 0 Newbie
    edited February 2021
    I have two accounts. I used two accounts alternately at work and at home. When I use my free account at home, I get a message that I used it commercially. I don't use it commercially at home. Please solve the problem.
    1. [removed per Community Guidelines] -> License
    2. [removed per Community Guidelines] -> Free
  • ivanoantonio
    ivanoantonio Posts: 0 Newbie
    I am using Teamviewer for a long time. i think i have an account since 12 years. I use my actual account since 2015.
    Today i tried to help my brother in law to install a program and I recieved the message that i got disconnected afther 5 minutes and i can't connect more... I found in the internet that connection is locked when there is a commercial use of teamviewer.
    The only people i am connecting to (as you see in the picture below) are: my mom pc , my sister pc , my brother in law PC and my uncle PC ... my personal laptop and home pc... and 2 android TV i have at home.
    Please note Nvidia SHIELD IS REPETEED 2 TIMES but it is only one TV.
    So considering that 3 of those are my personal computers, there are only 4 PC i am connecting to from Poland to my family in Italy. I do not think that it can be considered "commercial use" adding 4 computers in the last 8 years....
    Please help me to unlock the teamviewer free mode. Thank you!
  • Usik_Sviatoslav
    Usik_Sviatoslav Posts: 0 Newbie
    Hello, please tell me why I have a time limit? I have never used the program for commercial purposes and there is no need for this. I log into TeamViewer no more than twice a month. Why am I getting this limitation?
  • I am using a free version for educational purposes but it keep telling to buy commercial license due to heavy usage. I just recently wanted to start using it after more than 2 years not using it. How do I rectify it?
  • gustinn2
    gustinn2 Posts: 40 ✭✭
    Dear staff at Teamwiever.
    As i can see here some other users are getting same message like me this here:
    , "Connection blocked after timeout. Your license limits the maximum session duration to a partner, imediate reconnects are blocked. Please try again later or upgrade your license"
    as others here i ask .Was there a policy change?
    For 15 minutes I logged in and then got this message after it logged me out of my PC I have been using this free account for years and couldnt use it for over a month in september when your system thought i was using it for business use, after that i send you through your system pdf document undersigned that im using it for personal use and since then i have been using the service with no issues.
    I need to be able to connect lastly on friday.
    Kindly help me here and now and asap so i dont have to again to be out of using teamwiever for over a month like i had to in august to september last year.
    gustinn2
  • While_1
    While_1 Posts: 0 Newbie
    I am working in academia and have been using free TeamViewer license for quite some time to access my work computer from home. Today I started getting kicked from sessions after approximately a minute of use. Trying to reestablish connections results in a 1 minute block that gets prolonged for a random amount of times. Once unblocked, I can connect to my work computer once again, just to get kicked and blocked a minute later.
    Please help :)
  • I use free plan to connect my personal PC from mobile and laptop. Everything was fine but today it IS connected only on 1 minute and got "Commercial use". How to fix it?
  • montini
    montini Posts: 3 ✭✭
    Same here :(((
  • Lunneborg
    Lunneborg Posts: 7 ✭✭
    i have a free version to help friends and connect to my home computer from remote.
    it worked perfect untill the last update to 15.15.5.
    now i get timeout and it say i need to buy a licens.
    and im locked out and cant reconnect for som min.
    is this a bug or do i have to buy a license and all my friends and family to?
  • Igorb2005
    Igorb2005 Posts: 1
    I have same problem, and i would like to know how many devices must be for free license ?
  • mbacklund
    mbacklund Posts: 9 ✭✭
    I also got this:
    What is going on? 😠
  • Efe
    Efe Posts: 6 Newbie
    This isn't commercial usage detection right? I only use TV in my home network, I don't even try to connect somewhere outside of my LAN FFS. Why is it happening? I can only stay connected to my other PC for about 1 minute.
  • Lunneborg
    same for me byt my msg say i have to wait or buy a lisence.
    and i timed out to reconnect to the computer for some min and if i try to sone i get extra time out time.
  • Lunneborg
    dubbel post
  • Arczer
    Arczer Posts: 0 Newbie
    same here since yesterday. I've been using TeamViewer for many years to connect to my other laptop from time to time. I have never had this problem before. Please let us know how to fix it ?
  • zippolino
    zippolino Posts: 0 Newbie
    I use teamviewer not in a commercial manner.
  • JorgeL
    JorgeL Posts: 0 Newbie
    Got exactly the same problem since last night... after 15sec
  • IstvanSz
    IstvanSz Posts: 1 Newbie
    Now mine closes right away, and I didn't use it in a commercial manner either.
    When I try to connect it tells me to connect after 1 minute. When I connect after one minute it tells me immediately to connect after another minute.
    There are other weird messages also, about my account type changed, my password changed by an administrator.
  • JorgeL
    Same thing here.
    They're Team sent me a link for ''detection of commercial'' use but i am sure it's not that... since it doesn't say anything about this.
  • Efe
    Efe Posts: 6 Newbie
    I didn't receive any commercial usage warning, yet this happens
  • c_ertal
    c_ertal Posts: 0
    I got this
    Connections to this partner will be blocked until 19: 31 ."
  • JorgeL
    It's very annoying. It seems like the bug is fixed to people who have a subscription but for others like us(free version, personnal) they don't find a solution...
