I am using a free version for educational purposes but it keep telling to buy commercial license due to heavy usage. I just recently wanted to start using it after more than 2 years not using it. How do I rectify it?
Dear staff at Teamwiever.
As i can see here some other users are getting same message like me this here:
, "Connection blocked after timeout. Your license limits the maximum session duration to a partner, imediate reconnects are blocked. Please try again later or upgrade your license"
as others here i ask .Was there a policy change?
For 15 minutes I logged in and then got this message after it logged me out of my PC I have been using this free account for years and couldnt use it for over a month in september when your system thought i was using it for business use, after that i send you through your system pdf document undersigned that im using it for personal use and since then i have been using the service with no issues.
I need to be able to connect lastly on friday.
Kindly help me here and now and asap so i dont have to again to be out of using teamwiever for over a month like i had to in august to september last year.
gustinn2
I am working in academia and have been using free TeamViewer license for quite some time to access my work computer from home. Today I started getting kicked from sessions after approximately a minute of use. Trying to reestablish connections results in a 1 minute block that gets prolonged for a random amount of times. Once unblocked, I can connect to my work computer once again, just to get kicked and blocked a minute later.
Please help :)
I use free plan to connect my personal PC from mobile and laptop. Everything was fine but today it IS connected only on 1 minute and got "Commercial use". How to fix it?
Same here :(((
i have a free version to help friends and connect to my home computer from remote.
it worked perfect untill the last update to 15.15.5.
now i get timeout and it say i need to buy a licens.
and im locked out and cant reconnect for som min.
is this a bug or do i have to buy a license and all my friends and family to?
I have same problem, and i would like to know how many devices must be for free license ?
I also got this:
What is going on? 😠
This isn't commercial usage detection right? I only use TV in my home network, I don't even try to connect somewhere outside of my LAN FFS. Why is it happening? I can only stay connected to my other PC for about 1 minute.
same for me byt my msg say i have to wait or buy a lisence.
and i timed out to reconnect to the computer for some min and if i try to sone i get extra time out time.
dubbel post
same here since yesterday. I've been using TeamViewer for many years to connect to my other laptop from time to time. I have never had this problem before. Please let us know how to fix it ?
I use teamviewer not in a commercial manner.
Got exactly the same problem since last night... after 15sec
Now mine closes right away, and I didn't use it in a commercial manner either.
When I try to connect it tells me to connect after 1 minute. When I connect after one minute it tells me immediately to connect after another minute.
There are other weird messages also, about my account type changed, my password changed by an administrator.
Same thing here.
They're Team sent me a link for ''detection of commercial'' use but i am sure it's not that... since it doesn't say anything about this.
I didn't receive any commercial usage warning, yet this happens
I got this
Connections to this partner will be blocked until 19: 31 ."
It's very annoying. It seems like the bug is fixed to people who have a subscription but for others like us(free version, personnal) they don't find a solution...
Hopefully they find a solution for this asap
I am able to connect using **Third Party Product**, quick assist but no teamviewer.
I'm using TV from time to time and it worked but now the connection last a few seconds.
Why and can you solve the problem ?
I don't use it for professionnal use but only personal.
Hello after the update on 02/25, I can't connect because there is some limit !!! both computers have been updated to the latest version.if you manage to connect, the connection ends after several seconds !! I use teamviever privately, not commercially.
Suddenly TV times out after 10 - 20 seconds.
I am using TV free version, to 95% only among computers in my home. The other 5% is for friends and relatives.
I have updated to latest version (15.15.5)
Is this a temporary error, or are you making TV free version worthless?
The same thing here!.
I ask support to update my account **Please do not post email addresses** and remove the arisen limitation! I only use the teamviewer for personal purposes - to help relatives and friends!!! Thanks for understanding! Or tell me please what i have to do to fix that issue?
my connection times out after 1min saying the connection to a partner is limited. I used the partner ID to connect , not my user and password.
I am having the same problem. From my mobile it works fine, but when i try from my desktop it gives me 1 session for 55 secs then says i need to wait for 1 more minute.. but it never connects again.
It started yesterday and suddenly i was kicked out of my remote connection after 30 seconds saying that my license has limited remote whatever it was... i am using teamviewer for like 10 years now, doing what i was always doing, connecting to a couple of PCs i have at home, and now suddenly "suspecting commercial use"?
Really?
Any ideas?
many thanks in advance,
Alek
