1214215217219220402
  • I am using a free version for educational purposes but it keep telling to buy commercial license due to heavy usage. I just recently wanted to start using it after more than 2 years not using it. How do I rectify it?
  • gustinn2
    gustinn2 Posts: 40 ✭✭
    Dear staff at Teamwiever.
    As i can see here some other users are getting same message like me this here:
    , "Connection blocked after timeout. Your license limits the maximum session duration to a partner, imediate reconnects are blocked. Please try again later or upgrade your license"
    as others here i ask .Was there a policy change?
    For 15 minutes I logged in and then got this message after it logged me out of my PC I have been using this free account for years and couldnt use it for over a month in september when your system thought i was using it for business use, after that i send you through your system pdf document undersigned that im using it for personal use and since then i have been using the service with no issues.
    I need to be able to connect lastly on friday.
    Kindly help me here and now and asap so i dont have to again to be out of using teamwiever for over a month like i had to in august to september last year.
    gustinn2
  • While_1
    While_1 Posts: 0
    edited February 2021
    I am working in academia and have been using free TeamViewer license for quite some time to access my work computer from home. Today I started getting kicked from sessions after approximately a minute of use. Trying to reestablish connections results in a 1 minute block that gets prolonged for a random amount of times. Once unblocked, I can connect to my work computer once again, just to get kicked and blocked a minute later.
    Please help :)
  • I use free plan to connect my personal PC from mobile and laptop. Everything was fine but today it IS connected only on 1 minute and got "Commercial use". How to fix it?
  • montini
    montini Posts: 3 ✭✭
    Same here :(((
  • Lunneborg
    Lunneborg Posts: 7 ✭✭
    i have a free version to help friends and connect to my home computer from remote.
    it worked perfect untill the last update to 15.15.5.
    now i get timeout and it say i need to buy a licens.
    and im locked out and cant reconnect for som min.
    is this a bug or do i have to buy a license and all my friends and family to?
  • Igorb2005
    Igorb2005 Posts: 1
    I have same problem, and i would like to know how many devices must be for free license ?
  • mbacklund
    mbacklund Posts: 9 ✭✭
    I also got this:
    What is going on? 😠
  • Efe
    Efe Posts: 6 ✭✭
    This isn't commercial usage detection right? I only use TV in my home network, I don't even try to connect somewhere outside of my LAN FFS. Why is it happening? I can only stay connected to my other PC for about 1 minute.
  • Lunneborg
    same for me byt my msg say i have to wait or buy a lisence.
    and i timed out to reconnect to the computer for some min and if i try to sone i get extra time out time.
  • Lunneborg
    dubbel post
  • Arczer
    Arczer Posts: 0
    same here since yesterday. I've been using TeamViewer for many years to connect to my other laptop from time to time. I have never had this problem before. Please let us know how to fix it ?
  • zippolino
    zippolino Posts: 0
    I use teamviewer not in a commercial manner.
  • JorgeL
    JorgeL Posts: 0
    Got exactly the same problem since last night... after 15sec
  • IstvanSz
    IstvanSz Posts: 1
    Now mine closes right away, and I didn't use it in a commercial manner either.
    When I try to connect it tells me to connect after 1 minute. When I connect after one minute it tells me immediately to connect after another minute.
    There are other weird messages also, about my account type changed, my password changed by an administrator.
  • JorgeL
    JorgeL Posts: 0
    Same thing here.
    They're Team sent me a link for ''detection of commercial'' use but i am sure it's not that... since it doesn't say anything about this.
  • Efe
    Efe Posts: 6 ✭✭
    I didn't receive any commercial usage warning, yet this happens
  • c_ertal
    c_ertal Posts: 0
    I got this
    Connections to this partner will be blocked until 19: 31 ."
  • JorgeL
    JorgeL Posts: 0
    It's very annoying. It seems like the bug is fixed to people who have a subscription but for others like us(free version, personnal) they don't find a solution...
  • JorgeL
    JorgeL Posts: 0
    Hopefully they find a solution for this asap
  • GRAmcs
    GRAmcs Posts: 0
    I am able to connect using **Third Party Product**, quick assist but no teamviewer.
  • Herve77
    Herve77 Posts: 1
    I'm using TV from time to time and it worked but now the connection last a few seconds.
    Why and can you solve the problem ?
    I don't use it for professionnal use but only personal.
  • seta
    seta Posts: 1
    Hello
    after the update on 02/25, I can't connect because there is some limit !!! both computers have been updated to the latest version.if you manage to connect, the connection ends after several seconds !! I use teamviever privately, not commercially.
  • Betelgeuse
    Betelgeuse Posts: 8 ✭✭
    Suddenly TV times out after 10 - 20 seconds.
    I am using TV free version, to 95% only among computers in my home. The other 5% is for friends and relatives.
    I have updated to latest version (15.15.5)
    Is this a temporary error, or are you making TV free version worthless?
  • Betelgeuse
  • The same thing here!.
  • Lucaslive
    Lucaslive Posts: 0
    I ask support to update my account **Please do not post email addresses** and remove the arisen limitation! I only use the teamviewer for personal purposes - to help relatives and friends!!! Thanks for understanding! Or tell me please what i have to do to fix that issue?
  • my connection times out after 1min saying the connection to a partner is limited. I used the partner ID to connect , not my user and password.
  • Courior
    Courior Posts: 0
    I am having the same problem. From my mobile it works fine, but when i try from my desktop it gives me 1 session for 55 secs then says i need to wait for 1 more minute.. but it never connects again.
  • Hello,
    It started yesterday and suddenly i was kicked out of my remote connection after 30 seconds saying that my license has limited remote whatever it was... i am using teamviewer for like 10 years now, doing what i was always doing, connecting to a couple of PCs i have at home, and now suddenly "suspecting commercial use"?
    Really?
    Any ideas?
    many thanks in advance,
    Alek
