UserAgent contains "Windows" cause redirection to version 14
Our software download TeamViewer 15 from the link in the homepage, but it always result in installer of version 14. After investigation, I found that if UserAgent contains the word "Windows" then the link https://download.teamviewer.com/download/TeamViewer_Setup.exe redirect to https://download.teamviewer.com/download/version_14x/14.2.56676/TeamViewer_Setup.exe.
Could you please explain the behavior? If possible, please disable this redirection since our software requires using this UserAgent value.
  • vinhcomputer
    vinhcomputer Posts: 6 ✭✭
    Answer ✓
    Today I checked again and the problem was fixed.
    Thank you for your help 😊.
