I cam connect to desktop from my laptop. I recently went back to work from being remote for one year and I can not stay connect to my desktop at home.
why am i timing out after less then 30 seconds. Then I have to wait 1 minute continuously.
Has anyone had a problem with Teamviewer x64 throwing them out of a remote connection, after about 5 minutes or when you scroll the mouse?
I've been using Teamviewer free for years. I connect from my desktop to my laptop, that's it, and I've never had an issue. Now all of a sudden my session gets kicked out after about a minute and it's really really annoying. Why the **bleep** does it keep doing this? What happened?
I continue to get this on 2 PCs that I've introduced this on. The 3 different PCs never have this issue??
How would I fix these also machines so it doesn't break following 5 minutes.
Demo Version
TeamViewer Free doesn't permit associations with altered
Host module customers with your own organization logo. Kindly use
the essential Host module or the full form.
This meeting will be ended following 5 minutes
Happening for me too. I'm definitely not a commercial user. Super frustrating.
Add another person to the list here....Disconnected almost immediately. At one point, got a message that I was flagged for commercial use, which is ridiculous. Strictly personal use only between my own devices as well as to help troubleshoot my grandmother's machine.
Found this link and will give it a shot https://www.teamviewer.com/en/reset-management/
Hi experts,
Recently, every time I use TeamViewer, I get a timeout after just a few seconds.
What can be the reason for this and how can you fix it?
regards
Me too!
It worked for me just on the local, it only takes a couple minutes to download a nd install.
I am also having this issue.
The teamviewer keeps disconnecting and saying timed out then blocked for about 2 mins then does same again.
Tried a couple connections to my son and friend and same thing.
I've had similar in the past because it has thought I'm a commercial users but I'm not.
Just some pc's around the house, some old ones that don't exist no more and I help friends and family now and then online.
Before I remember there being somewhere to report the problem but can't see it this time.
Can anyone direct me to the right place to get this fixed?
Thanks,
Andy.
I think it started for me on latest update. Used to be somewhere you could let them know.
how to repair timed out
I have the same problem.
Hi! The same problem. After seconds timed out. The problem is that my father resides in a old people home and the visits are prohibited. (COVID). Any help ? Thx. Jordi
The same thing is happening to me. I am trying to help my grandmother in another state. Then I can't even log back on for another 15 min.
I have this issue as well trying to connect to my father in Texas from Michigan to help him with things. Seems to work ok if I connect to my office pc from my laptop but not across the internet. Session with my father ends quickly and then when try to reconnect get the following: Connection blocked after timeout. Seems like have to wait about 10 minutes to get a remote session again and then within 30 seconds the session ends.
Something must have happened in the March 23rd "security update", the forums here are packed with people having the same issue and no one from TV is responding. I guess this is their way of scrapping the private use version and pushing people to the full service. But who would waste the money on a product that seems to completely tank every few months?
Having the same problem and can't directly reconnect for 1 min according to message but does not work at all.
so i just can connect for ~30 seconds and have to wait more than 15 mins for next try -.-
when i try it from my smartphone it says that it could be commercial use but i'm not allowed to upload the pdf for clarification...
very disappointing because i already had this issue solved a few years ago when i used 10+ pcs (it was an experiment) and now i'm just connecting to my own devices and the one of my aunt and grandma...
do you guys get a similar message when trying to connect from smartphone?
Want to figure out if it's the same bug or something i really have to discuss with TeamViewer
Same here, went through the suggested ID reset and got:
"Dear User,
Thank you very much for sending your self-declaration of private use to us.
We have successfully reset the TeamViewer ID(s) you submitted via the form provided earlier.
We acknowledge that you are using TeamViewer for private use only on these devices.
And still have the very same issue. Not even the one minute timeout but just a few seconds and can't connect again.
I have the same issue. I use desktop PC, Plex server and mobile phone. I'm able to connect for approx a minute. After that it says connection is not possible and it will be blocked till timeout ends. It is showing time 1 minute in the future, but once this time is reached and I try again. It will just drop immediately, not even that minute works anymore. I tried the next days, the same thing happened. I don't get any message about violating terms & conditions, no working in saying I should buy some kind of premium. Just blocks it without proper explanation. If this is bug, than OK, but fix it please. If not, than it is quite **bleep** move from TeamViewer.
The whole system seems very slow but I had the same after just a few moments
I went through the ID reset process, they answered and acknowledged
"Dear User,
And still times out either right away either after 1 minute and cannot connect back. And same here trying to fix my elderly father's computer, the only way he can communicate with the world.
thank you , i installed the app and it does seem to be working, fingers crossed it remains.
Having same issue here. Very Frustrating! Had to use a competing product just to Remote In. A serious Bug! Please Fix!
I have the same issue. I connected to my kids machines today to help them with their taxes and after just a few seconds they both disconnect (timeout) and I can not re-connect. It shows I will be able to re-connect at a certain time, but when that time comes, it moves the time forward a minute or two.. Took 5 minutes to be able to re-connect and the same thing happens - times out after a few seconds, etc......
Hi Teamviewer,
Thanks ever so much for continuing to offer a Free account for non commercial use. I'm a Raspberry Pi hobbyist and love the clean access I get through Teamviewer. I recommend Teamviewer to everyone.
BUT this month I accidentally left some connections open for a long time. I did not know there was a connection time limit on the Free account. Is this new? Now I'm locked out of my Pi's as Teamviewer has been my only connection method.
SUGGESTIONS to make life a bit easier for Free users
- Warnings that your running out of connection time. Or a countdown timer on the console?
- Allow a short connection time such as 3 minutes or 5 minutes. Enough to fix a Wifi connection or enable SSH login.
- Tell us there's a time limit? Perhaps on the "Free for Personal Use" page? I still don't know what the time limit is. I read 17 hours a month somewhere.
Thanks,
A long time user that's normally very happy with your product.
I'm having the exact same issue. I've used this for a couple of years to help my mom and now it keeps timing out after about 30-60 seconds and then tells me it appears to be used commercially which it isn't. I don't see any solutions. Has TeamViewer responded to anyone?
