Remote update does not update
when I perform a remote update on my desktop at work from home the update starts, I get disconnected but when I reconnect the new version hasn't been installed. The previous version remains and the app tells me that an upgrade is available.
How can I resolve this?
I have tried several times and now it states that an update process is already running.
Hello @oliver_jones,
As you are running a 32-bit version on a 64-bit compatible device, you will need to manually uninstall TeamViewer and install the latest 64-bit version.
Once you have the 64-bit version installed, you will be able to do remote updates at anyime.
WOW! Yes, I am running a 32-bit version, I never noticed. It would be nice if the app was able to detect a 32-bit version running on a 64bit machine, and then warn you that the remote update is not possible, I wouldn't think that was too difficult. Instead, they prefer you to bash your head against a brick wall wondering why something so fundamental is not working.
Anyway, thanks for responding to my call for help, much appreciated, I will have to wait until I'm next in the office to upgrade to the 64-bit version,
kind regards,
Ollie
