How to connect to PC from mobile when PC is asleep
I recently added TV to my new computer and now if the application is closed or computer is asleep I cannot connect to my PC from my mobile device as I use to before. Is there a setting I need to select to be able to connect to my PC no matter if the application is running or not?
I can connect to my pc with no issues as long as my computer has the app open. If i close it i longer can connect. On my old pc i just got rid of i was able to connect whenever from remote even if the app was closed or computer was asleep. Is this something i need to adjust in the settings to be able to do again?
If the app is closed (and with closed I mean going to Connection ➜ Exit TeamViewer), no TeamViewer connection can be established.
TeamViewer has to be running (at least in the background) to be able to make a connection.
Your old computer most probably had a sleep mode that didn't kill the TeamViewer program - this is why it worked previously.
This seems not to be the case for your new computer.
There are no TeamViewer setting to could adjust for this scenario - it really depends on the hardware you are using.
Maybe you could look into the sleep mode settings of your new computer and see if you can adjust something there.
I just tried to see when I close the app by clicking on the x not exiting team viewer and the connection on my mobile device is not able to do it unless i open the app again.
I figured it out, you need to select "start team viewer with windows" on app
