why i get block from connect to my friend pc ???
I would like to express my appreciation to TeamViewer for the last several years for allowing me to occasionally help out my Church through remote access to manage the HVAC system. But I received a notice that I was not able to use the Private Non-Commercial version. I read the info and suppose that because the Church although non-profit does have paid staff was the determining factor. I also used it for assisting my 80+ year old brother before he passed away. It is wonderful tool and I will miss it. A big THANK YOU for allowing the use of the service. Take care
Dear Teamviewer,
I am trying to support my old mother on 88 - and get kicked off after one (1!!!) minute - thus making your software totally USELESS.
This is not the first time, I have experienced this - and thought that the wouldn't be a problem anymore.
However - I was wrong, and your software piles up in the stack of useless **bleep**!!
So I guess that's a goodbye after many years - I'll look for something more usable!
Givskov
I use Teamviewer to help my legally blind and deaf sister in law. She is using some magnifying software that makes her screen very large, like each letter about 2-3 inches on the screen!
Occasionally, she gets stuck and can't move on, usually some button to click that she can't see. My wife would drive all the way over there half hour each way, or 45 minutes rush hour traffic just so she can move on with what she is trying to do on her computer.
Also, I was using Teamviewer to access my other computer in the back of the house where my printer is to print documents on my printer. My printer is suppose to be wifi, but for some reason the wifi does not take. I can then access the computer back there that is wired to the printer to print something.
However, I got nabbed as suspected commercial use. I have tried to explain this to Teamviewer but I haven't heard back from them yet for several day. So far my sister in law is okay, but not forlong. I'm not using it for work, I print things for my religious congregation. Is this commercial use as per Teamviewer policy?
Leon
Hello
I want to cancel the ban on the program I have, as I only use it for home devices only (my children) currently I cannot access the devices and work on them for more than one minute, then the program is closed or the session is closed
using the free version of TeamViewer
I want a solution to this problem I have....thank you
I have no idea how this has happened, but now my sessions are time-limited. How can I prove that it's a free account?
this teamviewer support and accusations is terrible.
i went through the whole reset process, got a email saying that it was reset, but it didn't fix anything im still getting disconnected after 30 seconds.
Send in a reset appeal. See first post of this thread.
Hello. I use the program Team Viever To help my nephews because they can not handle the computer. I use this program only for private, non-commercial purposes. When trying to connect I gets a message that the free session is over and is blocked until e.g. 14:42 but when this hour passes I still can not connect. So why was my account blocked and I can no longer connect to help my nephew, to help my family. Can you unlock my account in some way? If yes, I would ask for it very much!
I am getting a request time out error whenever i try to connect the vpn for using TV. Is there any proper solution?
I'he been using free license Team Viewer for non-commercial use only – to connect to my home computer.
But after few minutes the connection is lost:
This was a free session sponsored by www.teamwiever.com.TeamViewer sessions are free of charge for personal use.
Your license limits the maximum session duration to a partner, immediate reconnects are blocked.
Can you help me with this problem?
[Removed as per the community guidelines.]
Hey, I'm getting a message "commercial use suspected" and then I get disconnected.
of course, I'm not using the software for any commercial use. I'm using it for my own laptop and pc and helping my family.
What should I do?
Thanks.
I'm using Teamviewer to help friend with their computer's problem. Recently, TV close the session after one minute and indicate that I'm "probably" using it for commercial use.
I'm not. How can I make it work ?
Thanks for the help.
Jérémie
I have been assisting my dad learn how to use his laptop and my other family members if they have an issue with their PC.. but recently im getting timed out.
i looked it up.. and i found out that because team viewer judges it as commercial and i have to subscribe.
i have a similar issue, randomly (once a year maybe) i receive a message stating that commercial use is suspected, it isnt and in for me to help my family f they have issues or to log into another computer of mine. i have used Teamviewer for years but this issue started about 2 years ago, after a while it goes back to normal? i am currenly getting this message and i have tried to get feedback before from TeamViewer via the app and have yet to receive a reply - 2yrs now.
From reading the comments is the only way to ask for a reset and see what someone decides? Is anyone aware of what makes the s/w think it is being used commercially?
regards
I have been playing by the rules. Yes I use this from a computer that is connected to a commercial environment. They have connected to my computer after I logged out, when I logged back in, I use it for personal use, however after 3 seconds I am booted out. $50 a month for 4 devices is a bit rich. a $1.00 a month per device, I could consider that. But again my use is for PERSONAL access. What gives?!?!
I'm using TeamViewer only for personal use when accessing my PC or helping out my 70 year old aunt with hers, however I can only stay connected for a minute after which TeamViewer disconnects me and tells me I'm using it for business.
I'm not using it for business, I do play fair so I'd appreciate if you could remove this restriction from my account.
I live in NY and have an 82 year old mother in Ohio. She is not able to do much on the computer and I used to be able to help her through team viewer. Now it kicks me out after 30 seconds. I do not use it for business as we have different platforms here and teamviewer is not one of them.
How do I resolve so I can help mom?
I have been using TeamViewer for many years to help family & friends out, but suddenly a few days ago, it started saying commercial use detected. I have never used TeamViewer for anything commercial. I found a reset request form & when I submitted it, two days passed & I got an email saying my account had been reset. When I tried using TeamViewer, I got the same message, so I checked all the information I had given & it was all correct. The only option it gave was to retry by doing the process again. At this point I have done the process over 5-6 times & I keep on getting the message, Commercial use detected & the connection timing out after a minute. I do not know what to do at this point. Has anyone had this before?
Please, how can we use the non-commercial license again? Recently, the program started telling me that your license only supports a certain session duration. I have only 6 PCs added in the TeamViewer Management Console, and when connected to each of them, the program will disconnect me after a few seconds. I want to use a non-commercial license to connect a PC to a friend and family.
thank you
Can you please delete my history of PCs?
I am using software for my personals PCs and you can see that is only 5 PC on the list.
Thanks in advace,
I'm pretty young and don't know if I should put this stuff in in the form.
I mainly use TeamViewer to connect to my media player pc. My usage of this software has not changed and this is the second time it has been locked due to false detection of commercial use.
I need it unblocked !
Many other people must be getting falsely blocked as I am again.
For over 7 months and submitting 4 forms to reactivate my account because I am 65 years old and did not want to travel up 12 stairs to the basement computer (personal computers) no COMMERCIAL USE, recent back surgery among others due to a car accident, thru no fault of mine, and still I can not log on without the same message "Commercial Use It appears TeamViewer is being used in a commercial environment".
There is no commercial environment when I have been on disability for many years and enjoy using the internet without climbing up and downstairs to my basement. I DO NOT KNOW WHAT ELSE I CAN DO TO GET REACTIVATED, AS THEY HAVE STATED 4 TIMES. Soon it will be eight months and I am going back in again for back surgery. HELP😣 PLEASE😪 Is this happening to you?
I've been using teamviewer for years. Lately when using on Windows, my connection timesout after a minute or less however on a MAC it does not timeout even though it is the same free account. I tried various fixes but nothing seems to work. Any ideas?
I assume that you have provided, on the RESET MANAGEMENT form, ALL of the Teamviewer ID's that you connect to. Therefore I can't help but wonder if there is something that is triggering the flagging of your account. Have you scrolled back in this thread a month or two to find any helpful hints? Did you read the first message in this thread along with the Blog that is mentioned in the first message? Some things I've learned that can trigger the flag is connecting to or from a work network system. Connecting to church, personal interest clubs (fishing, ham radio, etc), volunteer organizations...basically anything that is not personal at home connections. It has also been mentioned above that if you have a video conferencing program installed on your device, that may trigger the flag. If you can't find any helpful hints above in this thread, maybe it is a good time to start searching for another free provider. I found one that I have configured as a backup for me.
Dear community,
I've submitted the declaration for personal use of my TeamViewer account three times...
I received emails from the TeamViewer team two times that indicated my IDs had been reactivated, but I still failed to connect to my remote device. I submitted the declaration the 3rd time on June 1st, 2021, but I have not received the response and the reset webpage (https://www.teamviewer.com/en/reset-management/) still showed that my request is pending.
A message showed "Connection blocked after timeout. Your license limits the maximum session duration to a partner, immediate reconnects are blocked."
I would appreciate if any of you can provide insight or suggestion of how to solve this issue...
Thank you,
Samantha
I have the same issue since yesterday after the update! i cannot connect to the devices! and i cannot find how to contact the support!
I'm sure everyone is sick of these questions, but I've been trying to re-activate my PC for remote use for the past 2 months.
I have sent two requests to remove the flag for commercial use and both were granted, in one I thought listing my account is enough so the computers under it will be un-flagged, the second time I listed all IDs I use, but I still can't access my computer without timing out.
Is there anything to do here, or TeamViewer support is just the way it is and I should move on to greener pastures?
LIkewise, I have been advised on a few occasions that my IDs have been reset and service restored. Most times this has been proven false by not being able to connect for more than a minute or so between laptop and desktop. I did two weeks ago believe TV had cracked the problem, I had bilateral communication between them. However, just yesterday I entered the the TIMEOUT BLOCK zone once more.
Just WTH is going on with TV algorithms to propagate this misery for users who are "playing fair".
