Are you working with Insider Builds❓
Participate in our survey and get to know the new UI 👉 here 👈.
Touch mode not working on my Samsung Galaxy Tab S3 with a 10" screen
RayLodato
RayLodato Posts: 2 ✭✭
I am running the latest version of TeamViewer on my PC (15.18.5) and the latest version of the TeamView app on my Android tablet. When I connect to my PC, I only get Mouse mode. I do not even get the option to go into Touch mode. I've been searching these posts and it seems I should be able to select Touch mode with my size screen. Can anyone shed some light onto this issue?
  • JohnRocha
    JohnRocha Posts: 2 ✭✭
    I had this problem when I was connecting to the mobile device using the "Connect" dialog in the upper right corner of the PC's TeamViewer window.
    I got it to work by:
    1. Select "Remote Control" from the PC application's left hand panel. This changed the screen to show Allow Remote Control and Control Remote Computer.
    2. I selected "Remote Control" under "Control Remote Computer"
    3. I entered the remote partner ID
    4. I selected connect
    If I go though THIS route it works for me.
    Perhaps it'll work for you too?
    Good luck.
  • RayLodato
    Thanks for that, but I'm connection from my tablet to my PC, not the other way around. When I use my tablet to view my PC, I do not have the option for touch mode, but the documentation says I should. Can anyone shed any light on this?
